AniDutta
Dec 11, 2020Apprentice
RBK753 firmware update/ backhaul
Updated to the new firmware V3.2.16.22 and seems to be working fine. Backhaul connection between Router and satellites still at 1200 Mbps and not 2400Mbps as per specs. Per the Netgear website: AX...
Dec 12, 2020Guru - Experienced User
NG is aware:
AX4200 Tri-Band WiFi : 2.4GHz (600Mbps) + 5GHz (1200Mbps) for WiFi devices to connect to the Internet. 5GHz (2400Mbps) dedicated WiFi link for faster data connections between Orbi Router and Orbi Satellite.
- larryindublinDec 12, 2020Luminary
And here's some visual confirmation the backhaul is at 2400...
- MstrbigDec 12, 2020Master
Yep same here.
- Ace321Dec 14, 2020Apprentice
larryindublin what tool you are using to check this?
- MstrbigDec 14, 2020Master
Ace321 wrote:larryindublin what tool you are using to check this?
Not sure what app larryindublin used but I used telnet and logged into device.
