Nnyan
Oct 12, 2022Tutor
RBK753 firmware update
So I noticed that there was an upgrade to my RBK753. I went into the IP address for the router and it only showed an upgrade for the RBR750 and not the two satellites (V4.6.9.11). I went ahead and updated that. Now it will not list any clients connected, or the firmware of the two satellites. Online updates did not show any more updates.
When I head to the support page for the RBK753 (ex: https://www.netgear.com/support/product/RBK753.aspx#download) it shows that V4.6.11.1 is the latest. But I'm unable to manually update them the popup window (http://x.x.x.x/fwUpdate.htm) keeps giving a loading/can't reach page error or an HTTPS error). After a reboot the online update page now says "update failed" for the V4.6.9.11 on the RBR and RBS. I was able to redo the RBR but I can't update the RBS.
1 Reply
- ekhalilMaster
Please login directly on the satellites using their IP addresses (check which addresses are assigned to the satellites in the router) and do a manual upgrade. Downlaod the firmware from the Netgear Support page.
