vikrantl's avatar
vikrantl
Rbk753, high latency while ping to 192.168.1.1
I see high latemcy while pinging the router 192.168.1.1 over wifi
My tplink small router gave me range of latency from 1ms to 11ms.where 1ms was 90 in 100 times.
This netgear device gives me latency from 50 to 159ms.
How is that possible?
I am sitting at 1 m distance.
  • Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=17ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=105ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=104ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=5ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=57ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=33ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=39ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=109ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=12ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=60ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=75ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=34ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=111ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=20ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=81ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=29ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=73ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=70ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=117ms TTL=64
    Reply from 192.168.1.1: bytes=32 time=48ms TTL=64
    Reply
  • Have you found a solution to this? Not sure if I'm experiencing the same issue, I haven't checked my internet speed, pings, and if I have high latency. But I do occasionally experience slower site loading times since I switched routers.
