Dazza762
Feb 01, 2023Luminary
RBK753 IP address range
My systems IP address range (which I've not changed) is currently .2 to .254. Would there be any benefit to reducing this to say, .2 to .100? I'm also confused why this system is advertised to supp...
- Feb 01, 2023
I picked it up years ago from another router mfr. What they use. Worked well for me. Just kept that schema. No reason that .2 to .102 wouldn't do the same. Try it out. You can always go back or change to something else.
Feb 01, 2023Guru - Experienced User
The reason it says "up to 40 devices" but has a much wider ip range is it does support a lot more devices.
But when you look at the average user, you have streaming, gaming, etc that use a lot of bandwidth. High bandwidth devices are going to saturate it. But most users don't have 40 devices streaming at the same time (that'd be to much too) but a mix of IoT devices, streaming, phones, tablets, etc. So at average, 40 devices are what it supports. If you only had IoT devices that barely use any bandwidth, you could have much more.
Dazza762
Thanks. So what about my question re reducing the IP address range. Would there be any point in doing that?
- plemansFeb 01, 2023Guru - Experienced User
Not really.
- FURRYe38Feb 01, 2023Guru - Experienced User
If found that DHCP seems to run a bit better and more stable with a smaller DHCP IP address range. I've been running .100 to .200 for years now. Just now getting upwards of 40 devices after many years of being at 30 or under. Most homes don't have tons of devices that would need a full DCHP range which is most cases would be never used entirely.
Also changing the DHCP IP range to something smaller, can allow for some STATIC IP Addressed devices to be configured, if needed. Devices like printers, NAS, controllers and devices that don't need much router management and you want them to be static addresses, this comes in handy sometimes.
- Dazza762Feb 01, 2023Luminary
Thanks. Thats's what I'd heard as well. Any reason for .100 - .200 rather than .2 - .102?
