Dazza762
Feb 01, 2023Luminary
RBK753 IP address range
My systems IP address range (which I've not changed) is currently .2 to .254. Would there be any benefit to reducing this to say, .2 to .100? I'm also confused why this system is advertised to supp...
- Feb 01, 2023
I picked it up years ago from another router mfr. What they use. Worked well for me. Just kept that schema. No reason that .2 to .102 wouldn't do the same. Try it out. You can always go back or change to something else.
Dazza762
Thanks. Thats's what I'd heard as well. Any reason for .100 - .200 rather than .2 - .102?
Feb 01, 2023Guru - Experienced User
