Angusl
Oct 08, 2024Follower
RBK753 Losing Internet
Hardware type: Orbi Hardware Version: RBR750 Firmware Version: V7.2.6.31 (latest as of 10/8/24) Purchased: 8/2/2024 Satellites: 2 Backhaul: LAN (Cat 6, Daisychain) Distance to Satellites: Sat...
Oct 08, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Front LED being RED or PINK means the RBR isn't getting a good connection from the ISP modem or ONT.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
