ChrisGtr
Oct 02, 2023Aspirant
rbk753 mesh and calix gm2037 install later this week
I am runnning rbk753 mesh system with 2 satelites currently, Later this week fiberIq will be installing a line to my house and inside. My question is - will I be running into any trouble? Cal...
CrimpOn
Oct 04, 2023Guru - Experienced User
Observations:
- This is a freakish amount of bandwidth.
- Wonderful that you have an Ethernet adapter capable of 4200Mbps to verify this speed.
- Annoyed that the Calix Product Data Sheet does not mention WAN and LAN ports capable of greater than 1GB.
(Obviously if you measure 4200, then the WAN port and at least one LAN port must be capable of higher than that speed.) - Surprised that the Orbi upload speed reported at 45MB/sec when the download speed reported at 1000.
- There are only two models of Orbi residential systems with greater than 1GB WAN ports:
- The RBR860 WAN port supports up to 10GB, but the four LAN ports all max out at 1GB.
This means that 4.2GB data stream could be shared among a lot of devices (both wired and WiFi), but no single wired device will get more than 1GB and the WiFi devices will max out at whatever their chipsets support.
WiFi6 (802.11ax) devices may be capable of 1GB. - The RBRE960 WAN port supports 10GB plus it has one LAN port rated to 2.5GB plus three 1GB LAN ports. Users commonly feed the 2.5G port into a 2.5G switch and connect 960 satellites and computers to that switch. That still leaves bandwidth "on the table" and available to the router wired ports and the router WiFi devices.
- There are a number of routers on the market supporting 4200Mbps WAN connections:
https://www.netgear.com/home/wifi/routers/rs700 (Netgear's 960 is in the second half of the article). Some of those systems have faster LAN side ports than any Netgear Orbi system. - It might be worth asking the ISP about the cost of using their WiFi router plus enough WiFi satellites to provide coverage to the desired area. Their product appears to be roughly equivalent to the Netgear 960 (and perhaps to some of the other products). A Netgear RBRK963 sells for about $1,500. If the ISP wants $150/month, then the break-even would be 15 months. If they ask only $50/month, then the break-even would be 45 months.
ChrisGtr
Oct 04, 2023Aspirant
i stil have the issue of the orbi not connecting lol, go figure.
- CrimpOnOct 04, 2023Guru - Experienced User
Not connecting directly to the fiber ONT, or not connecting to the Calix router?
- ChrisGtrOct 04, 2023Aspirant
i have internet from modem hard lined to computer.
i hav done the following
I have a mesh orbi rbk753-100nas Wifi 6 mesh system. iq fiber installed a modem calix gigapoint gp1101x model 100-05638. This is fiber Internet works when connected straight to modem, 4200 up 4200 down. mesh system can not connect to the internet. I have done the following: Unplugged mesh system, Disconnected all Ethernet cables and reset. Hard reset mesh orbi Ipconfig renewed IP After 3 hard resets I was able to get into factory mode. and we still can not connect to internet.
Thanks for clarifying.
The GP1101X Optical Network Unit (ONU) provides one auto sensing Ethernet port capable of 100/2500/10G. (It is really annoying that they do not let us download the Product Data Sheet - requires a login/password - because we can only guess if "1000" was left out by accident or if the Ethernet port does not actually support 1000MB (1Gigabit). I'm guessing this is a simple typo. )
When a Windows computer is connected directly to this Ethernet port, it connects successfully and Ookla Speed Test reports upload/download speed of 4200/4200. There is probably an after-market Ethernet adapter in the computer because most computers come with gigabit Ethernet adapters.
The Orbi RBR750 router has been Factory Reset, and thus needs to be configured.
Power off the ONU for a minute so it wlll 'forget about' the Windows computer that was connected previously.
Most older people would connect the Windows computer to one of the Orbi LAN ports, power up the Orbi, and open a web browser to http://orbilogin.net (or to http://192.168.1.1 ) - Younger people would probably whip out their smartphone, but more on that later.
When I do this, the first page attempts to talk me into using the Orbi 'app' to configure the system, and I go to the bottom of the screen to find the prompt I do not have a smart phone. (It's none of their damn business whether I possess a smartphone or not. I just want to use the web method to set up the system.)
Power Up the ONU.
Connect the Orbi router to the ONU with an Ethernet cable.
Since the ISP provided no information stating that their system requires a user name and password, and the Windows computer connected correctly, select "No login required."
and this doesn't work???
