SGDH
Apr 01, 2021Aspirant
RBK753 Orbi Nest mesh WIFI - What is the cheapest add on Satellite I can purchase?
Re: Model RBK753 AX4200 WIFI 6 Mesh (Router + 2 satellites). - Sorry did not find model search! I have just purchased this for our bungalow and it is brilliant, except the wifi does not reach t...
Apr 01, 2021Guru - Experienced User
NGs EX7500, 7700 and 8000 model extenders work with Orbi AX. There extenders only so the backhaul will not be used when these are connected. Works in a pinch though. I believe the EAX80 works as well however thats a bit more expensive.
SGDH
many thanks - justr picked up the 7700 on Amazon for £90 so will try and hook up and see how we go.
- FURRYe38Apr 01, 2021Guru - Experienced User
Make sure the FW is up to date on EX7700 before trying to connect it. It may not connect initially. I just updated mine yesterday and will working. :smileyvery-happy:
- SGDHApr 01, 2021Aspirant
Will do. Thanks for the tip. Does it connect into the existing 5Ghz backhaul channel of the existing Orbi system to get the internet feed and then distribute via its own 5Ghz and 2.4 Ghz channels? I guess it does as it is tri band. For my 2 orbi satellites I have one connected via etghernet, and one connects via 5ghz back haul. Will the EX7700 work in the same fashion as the second satellite i mentioned.
Thanks, but of a novice so appreciate the assistance!
I don't believe it will, I believe the EX7700 2nd 5Ghz radio is for routers with tri band front haul signals. The Orbi is only for back haul and with in the Orbi system between the RBR and RBS only, which is not accessible for anyone.
