SGDH
Apr 01, 2021Aspirant
RBK753 Orbi Nest mesh WIFI - What is the cheapest add on Satellite I can purchase?
Re: Model RBK753 AX4200 WIFI 6 Mesh (Router + 2 satellites). - Sorry did not find model search! I have just purchased this for our bungalow and it is brilliant, except the wifi does not reach t...
Apr 01, 2021Guru - Experienced User
Make sure the FW is up to date on EX7700 before trying to connect it. It may not connect initially. I just updated mine yesterday and will working. :smileyvery-happy:
SGDH
Will do. Thanks for the tip. Does it connect into the existing 5Ghz backhaul channel of the existing Orbi system to get the internet feed and then distribute via its own 5Ghz and 2.4 Ghz channels? I guess it does as it is tri band. For my 2 orbi satellites I have one connected via etghernet, and one connects via 5ghz back haul. Will the EX7700 work in the same fashion as the second satellite i mentioned.
Thanks, but of a novice so appreciate the assistance!
- FURRYe38Apr 01, 2021Guru - Experienced User
I don't believe it will, I believe the EX7700 2nd 5Ghz radio is for routers with tri band front haul signals. The Orbi is only for back haul and with in the Orbi system between the RBR and RBS only, which is not accessible for anyone.
