orbira
Sep 01, 2020Apprentice
RBK753 Port forwarding not working from LAN hosts
Hi, I just installed Orbi RBK753 in router mode. There is no router in front of it and the netgear router is directly connected to WAN. I have setup port forwarding to forward https (port 443) to...
- Sep 06, 2020
Hi Orbira,
I have had no issues with port forwarding at all before and after the hot-fix. The hot-fix firmware which is for the router only has definitely resolved my NAT loopback issue with the RBK852 satellite.
I have DM'ed you with my case number.
Good luck!
Sep 01, 2020Guru - Experienced User
Im not sure if this is supported on Orbi. I believe that may need Loopback support. I would ask NG support about this to see if this configuration is possible.
- orbiraSep 01, 2020Apprentice
Per the article Which NETGEAR Routers support NAT Loopback, RBR750 is listed there.
Orbi products:
- RBR850
- RBR750
- RBR50v2
- RBR50v1
- RBR40
- RBR20
- RBR10
In any case, this is a big showstopper as I cannot connect to my WebDAV server from my phones/other machines and for me to be able to access them from outside or within LAN, this has to be functional :(. I have opened a support ticket with NETGEAR, let's see what they say.
Thanks
- Mikey94025Sep 01, 2020Hero
Does it work if you try forwarding a different port than 443 from the WAN IP (still forwarded to 443 on your internal NAS host)? There have been issues with certain standard port numbers and I'm surprised 443 works at all.
- orbiraSep 01, 2020ApprenticeI have many other ports forwarded other than 443. I used 443 just as an example. The other port I tried was 22 (ssh). From an outside machine I can connect just fine ensuring port forwarding is setup right. However from with the LAN, the connection just hangs. Looking at orbi router logs external connection gets logged. Attempt from inside doesn’t even gets logged.
I will try some random port as well just to ensure if port 22 is also defined port.
Thanks
- FURRYe38Sep 01, 2020Guru - Experienced User
Good find, thanks for letting us know.
Keep us posted on how it goes...
orbira wrote:Per the article Which NETGEAR Routers support NAT Loopback, RBR750 is listed there.
Orbi products:
- RBR850
- RBR750
- RBR50v2
- RBR50v1
- RBR40
- RBR20
- RBR10
Thanks
- mcgarryvOct 27, 2020Tutor
Hi,
I've found a work-around my issue with my new RBK753S Orbi System (RBR750 Router) where the port-forwarding stopped working a few minutes after a reboot or some setting applied to router.
By disabling the UPnP (Universal Plug& PLay) feature, I am now able to successfully access my internal devices/LAN from an external network.
Vince
