orbira
Sep 01, 2020Apprentice
RBK753 Port forwarding not working from LAN hosts
Hi, I just installed Orbi RBK753 in router mode. There is no router in front of it and the netgear router is directly connected to WAN. I have setup port forwarding to forward https (port 443) to...
- Sep 06, 2020
Hi Orbira,
I have had no issues with port forwarding at all before and after the hot-fix. The hot-fix firmware which is for the router only has definitely resolved my NAT loopback issue with the RBK852 satellite.
I have DM'ed you with my case number.
Good luck!
Sep 05, 2020Guru - Experienced User
Thanks for letting us know. Let us know if this resolves this Port Fowarding issue as well. IF so, please mark it as solved so others will know.
Thank you.
orbira wrote:
How do I get access to those? I don’t see a firmware upgrade available. Can you please provide me with your case number and I can ask them to give me the same hot fix.
Thanks
pickwit
Sep 06, 2020Tutor
Hi Orbira,
Good luck!
- orbiraSep 08, 2020Apprentice
I am marking this as a solution, even though I don't have the hotfix firmware, but the firmware is actually just setting bridge-nf-call-iptables to 0 and I have been using that as a workaround by
echo 0 > /proc/sys/net/bridge/bridge-nf-call-iptables
Thanks everyone for helping out with this.
