Camaroon83
Dec 08, 2021Aspirant
RBK753 Satellite LED Power Light Solid Red
Hi all, just recently bought a factory refurbished Orbi RBK753 system from woot.com. Set it up the other day and everything seemed to go smoothly. All three devices (router and two satellites) needed...
Dec 08, 2021Guru - Experienced User
Sounds like the RBS is bad and needs replaced.
- Camaroon83Dec 08, 2021Aspirant
Yeah, seems that way. Netgear support just called me back and told me to contact woot to see if they can replace, and they're checking to see if they can replace it on their end as well. Thanks for the response!
- FURRYe38Dec 08, 2021Guru - Experienced User
đ
