ihsteven
Jun 03, 2020Guide
RBK753 vs RBK753s
Does anyone know what the difference is between the rbk753 and the rbk753s ? https://www.netgear.com/orbi/rbk753s.aspx (S model) https://www.netgear.com/orbi/rbk753.aspx (regular one) -Stev...
- Jun 03, 2020
RBK753s : 1 year Armor subscription included
RBK753: Armor free trial period only
"s" probably means "subscription".
Jul 04, 2020Guru - Experienced User
All the 7 series are the same accept the the addiional RBS 752 vs 753. THe code base is the same between the 7 and 8 series.
I don't use Port Triggering or Forwording for gaming. Just uPnP and set NAT Filter for OPEN works for two game consoles.
coldkeyes wrote:Hello; I had a question about Port Triggering/Port Forwarding
is there a limit on how many you can do on the RBK573 and RBK573s?
I am looking to be able to play games on xbox live, psn, steam, origin, uplay and make sure to get reliable twitch streaming connection
Can someone confirm this for me please?
I am looking to buy a high end powerful router for my network
I have ATT Uverse and I have 120mb down and 20mb upload speeds
I hate the modem gateway unit so much; I can't stand it having no port triggering/port forwarding options
So I want to know before I purchase this either the RBK753 or RBK753s
coldkeyes
Jul 04, 2020Aspirant
I port trigger for things like steam, origin, uplay, and xbox live
I always do port triggers
However I was wondering if anyone knows it has limits on how many I can do
- FURRYe38Jul 04, 2020Guru - Experienced User
I find the following listed on my RBRs Help Center link at the bottom of the page for PF and PT:
"Port Assignment
You can make up to 20 different port assignments for Internet services, applications, or games. In the Service Name lists, you can select a service, an application, or a game. If you do not see an item that you want to use in any of the lists, check with the software or game developer for the correct port numbers to use."
