Serranopr
Nov 28, 2022Tutor
RBK753 why does reset router needed to reconnect dropped device? (Lennox S30 thermostat)
Periodically one of my Lennox S30 thermostats will drop WiFi connection. When I try to reconnect it is unsuccessful and times out. However if I go to the Orbi and do a router reset, and then try to...
Nov 28, 2022Guru - Experienced User
What do you mean by a router reset. Reset usually means that you factory reset the system and setup from scratch.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
