Serranopr
Nov 28, 2022Tutor
RBK753 why does reset router needed to reconnect dropped device? (Lennox S30 thermostat)
Periodically one of my Lennox S30 thermostats will drop WiFi connection. When I try to reconnect it is unsuccessful and times out. However if I go to the Orbi and do a router reset, and then try to...
Serranopr
Nov 28, 2022Tutor
What I mean by reset is actually going onto the orbi admin web interface and doing a Router "Reboot".
When the thermostat shows no connection to the WiFi (it got dropped), going to that device and trying to reconnect fails. The network shows plenty of signal strength (-40dbm or so), however you can try and try again and it will simply timeout, connection failed. However if I go to the Orbi admin, and do a router reboot, wait for Orbi to completely come back up and then attempt to connect the thermostat it will connect on the first attempt. It seems like doing the router reboot is flushing something, and then the reconnection attempt is successful. My setup is a Motorola modem (latest) supporting Comcast ISP and Gig speed, very low latency. The thermostat hub is in the attic and probably closest to a wired Orbi satellite, but there is some ductwork and it may see the main Orbi router better which is perhaps 25 feet away.
Orbi RB753 with current firmware (no updates available) V4.6.9.11_2.3.5
| Region | North America |
| 2.4 GHz Channel | Auto (5) |
| 2.4 GHz Wireless mode: | Up to 1147 Mbps |
| 5 GHz Channel | 36 + 40 + 44 + 48(P) |
| 5 GHz Wireless mode: | Up to 2402 Mbps |
- FURRYe38Nov 29, 2022Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.- SerranoprNov 29, 2022Tutor
The home is >4000ft.
RBR router ------> wired> --- Sat1..........wireless Sat 2
thermostat
Thermostat is between Router & Sat1, and the admin web interface for Orbi shows it is connecting to the thermostat on the main Router, 2.4Ghz.
Possible that the thermostat is having a hard time keeping connected due to all the wifi signals coming from the RBR and the two RBS.
For that size of home, you only need the RBR and one RBS. https://youtu.be/UR0viMLISz4
Try this, Turn OFF 1 RBS.Set the Transmit power on the RBR to 50%. Set 40Mhz co-existence. Under Advanced Tab/Advanced Settings/Wireless Settings
Set manual channel 1 and 40.
