Mizer39376
Dec 15, 2020Aspirant
RBK753 WiFi and Lan
The other day I lost internet to my ISP and noticed that I had no way to access the internal network, WIFI and Lan connected. Is there a configuration I need to use? It seems odd that I can't connect ...
Mizer39376
It is setup as wireless, no wired back haul. Also main router is plugged directly into the ISP, no modem. The router is handing out IP via DHCP. I get connected with no internet, but I get no wireless signal and can't connect to anything internally. I can't even get to router by http://192.168.1.1, so not using dns either.
Mstrbig
Dec 15, 2020Master
You must have something setup wrong
- Mizer39376Dec 15, 2020AspirantThat really was not helpful.
- MstrbigDec 15, 2020Master
Mizer39376 wrote:
That really was not helpful.If you post your settings I could be more helpful
