Mizer39376
Dec 15, 2020Aspirant
RBK753 WiFi and Lan
The other day I lost internet to my ISP and noticed that I had no way to access the internal network, WIFI and Lan connected. Is there a configuration I need to use? It seems odd that I can't connect ...
Dec 15, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Has a power off for 1 minute then back on been performed since last update?
Mizer39376 wrote:
The other day I lost internet to my ISP and noticed that I had no way to access the internal network, WIFI and Lan connected. Is there a configuration I need to use? It seems odd that I can't connect to internal WiFi if I lose external WAN connection.
