rossy100
Sep 17, 2020Follower
RBK753 Wifi settings
Hi all Just upgraded from RBK53 to RBK753. Speeds seem improved so far. What are the recommended wifi settings for this? (20/40 coexistence, WMM, CTS/RTS threshold etc.) I couldnt find a...
Sep 17, 2020Guru - Experienced User
Leave them at default. If your confident that your system will work with all of your devices well on 40Mhz only, then you can change this.
CTS has a new default of 64 which NG recommends using. Some users have experienced connection issues. So you can change this to 2347 to test to see if this resolves anything. WMM should always be enabled.
