LBX5JK
Apr 25, 2022Aspirant
RBK753 Wifi Speeds
Set-up Sky Gigafast product installed to the house. (900Mbps) Sky Hub 4 (SR203) connected via CAT6 to ONT. Netgear ORBI RBK753 (in AP Mode) connected via CAT6 to Sky Hub 4. x2 Netgear ORBI RBK753...
Apr 25, 2022Guru - Experienced User
What WiFi devices do you have connected for speed testing?
- LBX5JKApr 25, 2022Aspirant
Variety of apple devices (iPhone 12 Pro Max and 2021 MacBook Pro)
- FURRYe38Apr 25, 2022Guru - Experienced User
Ok, I have a 12 pro max as well though MBP is only 2018 so no AX on it.
• Orbi AX4200 Router and AX4200 Satellite
(600 + 1200 + 2400Mbps)†1200Mpbs on 5Ghz so nearest you see is around 400-500Mpbs while nearest the RBR.
