ClinicalYoda
Oct 09, 2020Aspirant
RBK753 Wireless Printer issues
Just setup RBK753. Very curious issue. After a lot of trouble i was able to setup my HP 3050 wireless printer. The problem is, when the printer connects to router, it works just fine, but when i have...
Mikey94025
Oct 09, 2020Hero
ClinicalYoda wrote:Printer shows connected in both situations, it gets IP address (192.168.1.3), buy when connected to satellite, i cannot ping it, when connected to router, i can ping it.
What is the IP address of the device you're trying to print from and what kind of device is it? There should be seamless connectivity between devices on the Orbi network regardless of whether connected to the RBR or RBS.
Some customers have connectivity issues because they have some devices on the Orbi and others connected to the upstream ISP modem/router - They should switch all devices to the Orbi (wired and wireless). Since you can print if the printer connects to the RBR then likely that is not the case for you.
How is your RBS networked to the RBR, i.e., is it wireless or wired? If wired, is there a network switch inbetween (some switches, especially managed or green ones, cause connectivity problems).
ClinicalYoda
Oct 10, 2020Aspirant
The device IP i am trying to print from is 192.168.1.8, but i have the same problem printing and pinging from any of my devices.
I have verizon FIOS and RBR is connected to ONT.
RBS is conected to RBR wireless.
