ClinicalYoda
Oct 10, 2020Aspirant
RBK753 Wireless Printer issues
Just setup RBK753. Very curious issue. After a lot of trouble i was able to setup my HP 3050 wireless printer. The problem is, when the printer connects to router, it works just fine, but when i have...
ClinicalYoda
FURRYe38 wrote:What Firmware version is currently loaded?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
IF you connect a PC to the RBS with the printer connected at the RBS, can the PC access the printer then?
The Firmware is latest V3.2.16.6 for both RBR and RBS
RBR and RBS distance is about 30 feet, signal is strong all over the home.
Even if i connect the PC to same RBS as Printer, still cannot ping the printer.
Any suggestions appreciated.
