Wim2019
Mar 02, 2025Aspirant
RBK753 with extra RBS750, satellites led goes every 20 minutes to white and blue. Why?
I bought a Orbi RBK753 set in begin 2022. I had no problems till I changed this year from internet provider. The RBK730 has to be installed as access point (AP). I bought also a new RBS750 to joint t...
Mar 02, 2025Guru - Experienced User
Does turning OFF the other RBS and leavin the new RBS ON do same thing?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
