alex81388
Dec 21, 2020Aspirant
RBK753: Wyze cams (other 2.4ghz devices) can't connect
I'm unable to connect my previously functioning 2.4ghz devices to the new Orbi mesh network. Let's focus on the Wyze cams for now. I have the v2 and v3. I've tried a few things: Cutting the 5ghz...
- Dec 21, 2020
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
CrimpOn
Dec 21, 2020Guru - Experienced User
alex81388 wrote:I'm unable to connect my previously functioning 2.4ghz devices to the new Orbi mesh network. Let's focus on the Wyze cams for now. I have the v2 and v3. I've tried a few things:
I have two Wyze cams, both of which commected immediately to my (original) Orbi. The "good thing" about cameras is that they almost always set up by creating a QR code that the camera can scan. Two questions:
- Does the new Orbi have exactly the same SSID/password as the previous one?
I always give each new router the same credentials as the one that is being replaced because (a) all of my devices will simply connect without having to be set up again, and (b) if I decide to "go back", I can simply swap the routers and devices will connect again to the old one. - Is this system in a country that allows channels 12 & 13?
