sgreensides
Oct 11, 2022Aspirant
RBK753
Network = modem/router with WiFi disabled. Ethernet(1) to Orbi - to Orbi then ethernet to Humax Media Server Ethernet(2) to gigabyte switch to both Synology NAS and Apple Time Capsule. MacBook ...
- Oct 17, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Oct 11, 2022Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are RBS ethernet or wirelessly connected to the RBR?
What is the Mfr and model# of the ethernet switch in the configuration?
If you turn OFF the RBS and just connect everything to the RBR, do you see same problem?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Not first time NEST products have had issues on MESH systems.
