sgreensides
Oct 11, 2022Aspirant
RBK753
Network = modem/router with WiFi disabled. Ethernet(1) to Orbi - to Orbi then ethernet to Humax Media Server Ethernet(2) to gigabyte switch to both Synology NAS and Apple Time Capsule. MacBook ...
- Oct 17, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
sgreensides
Oct 16, 2022Aspirant
Thanks for all your help
Old enough to remember ethernet and building in redundancy by adding alternative routes and thought (mistakenly) that this was now a good idea with the wifi and DHCP - oops.
Orbi now only connection to disabled modem/router and then everything else down stream connected to the Orbi mesh and it WORKS like a dream.
Many thanks to all
- FURRYe38Oct 17, 2022Guru - Experienced User
Enjoy. 📡
