kgurney
Aug 30, 2020Tutor
RBK753S - Alex Echo Gen 3
I recently purchased the ORBI RBK753S WiFi Router for my home. I purchased this device due to its ability to support 40 connections. However, I recently purchased a new Alexa Echo Gen 3 and was u...
Aug 31, 2020Guru - Experienced User
Be sure to post in the Orbi AX forum for you model Orbi.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
I have a 1st and 3rd gen Dot connected to my Orbi AX system.
Good Luck.
kgurney wrote:I recently purchased the ORBI RBK753S WiFi Router for my home. I purchased this device due to its ability to support 40 connections. However, I recently purchased a new Alexa Echo Gen 3 and was unable to connect the device. I spoke with two different people in technical support neither of them were able to resolve the issue.
I find it hard to understand why this problem is not well documented and that their is no easy fix to the problem. I think we would all agree the Echo Gen 3 device is very popular today and thus this issue must be impacting the satifaction of this WiFi Device.
My next step is to return it Costco if I don't get a quick and easy answer to this problem from this note.
Thank you in advance for your help.
