njweb
Apr 29, 2021Luminary
RBK753S - Much slower wifi speeds after AUTO firmware upgrade to 3.2.18.1! 3.2.17.x was MUCH faster
I had intentionally downgraded my RBK753S from 3.2.18.1 to 3.2.17.x and with 3.2.17.x, everything was great! But this morning I noticed that my firmware updated automatically to 3.2.18.1, which seem...
- Apr 29, 2021
Quick update - Since I am / was experiencing the low speeds noted above (330 - 350 Mbps), I just disconnected and reconnected my Netgear A7000 wifi adapater from the network in Win 10 (did NOT unplug it).
After reconnecting to the network, speeds improved to 430 Mbps on first run after reconnecting, then 471 Mbps, 476 Mbps, 468 Mbps, one slower one of 451.7 Mbps but much better than before the disconnect/reconnect, and then 470 Mbps.
Will monitor stabilty after a few hours and also after a full day or two / after restarts / hibernates/ shutdowns etc.
njweb
FURRYe38 wrote:Did you power OFF the RBR and RBS for 30 seconds after the update or factory reset and setup from scratch?
Something to contact NG support about and let them know.
Thanks.
Unfortunately, I could not power off and restart the router / satellites yet since that takes too long given I was working and on a call and wife is on a call now. A quick adapter disconnect / reconnect right after my call was less intrusive.
I can try when we are both not actively on calls / responding to emails etc.
In the meantime, will run some more tests...
njweb
Very happy to report that for now, wireless speeds have stabilized, ever since the 10:24 AM test I referred to above. Also no wifi connection issues (tested using my Netgear A7000 USB wifi adapter).
The true test, based on my prior experience, will be seeing how it holds up, in terms of continued stability, over the next day or so...
So long as speeds hold up and I have no disconnects the next day or two, I will consider this 'solved'.
My plan is 400/10, but as you can see, I am getting almost 480 Mbps wirelessly.
Date/time......Ping.Download. Upload.
| 04/29/2021 9:57 PM | 11 | 475.84 | 11.97 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
3:23 PM | 12 | 478.38 | 11.77 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
12:45 PM | 12 | 445.95 | 11.72 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
10:43 AM | 13 | 466.39 | 11.91 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
10:30 AM | 12 | 469.99 | 11.72 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
10:29 AM | 12 | 451.69 | 11.95 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
10:28 AM | 12 | 468.44 | 11.94 | ~ 50 | New York, NY Surfshark Ltd | XFINITY | |
10:25 AM | 12 | 476.31 | 11.94 | < 50 | Matawan, NJ Vultr | XFINITY | |
The 10:24 AM test got 471.09 Mbps did but not copied / pasted...
- FURRYe38Apr 29, 2021Guru - Experienced User
Ran a few tests myself on my 8 series with v1 loaded: Armor/TM disabled. DST Enabled. CTS set to 64(default)
Mac Book wireless connected to RBR: 866Mbs Connection Rate
Mac Book Pro Connected near the RBR: 1300Mpbs Connection rate which is max rate for Mac Book Pro 2018
Mac Book Pro wire connected to a NG R7800 router in wireless bridge mode connected at 1733Mbps to RBR:
- njwebApr 30, 2021Luminary
Furry - Nice results (above)!
I ran my FIRST Speedtest of the day and immediately got 473.42 Mbps out of ~480 Mbps provisioned, so it looks like I may stick with 3.2.18.1 since it appears to be working well! :)
Will wait till Satruday evening or Sunday morning to consider this solved to be safe (i.e. I want to ensure stability over several days).
I need to check and monitor my TiVO MoCA connection though.
- FURRYe38Apr 30, 2021Guru - Experienced User
I may go back and re-test with CTS set to 2347 and see how that does.
