campolo313's avatar
campolo313
Apprentice
Jul 30, 2020
RBK753S - Xbox Causes Router to Reboot, Occasional Double NAT
Hello, I recently changed from the Orbi RBK53 to the Orbi RBK753S, and now I am having issues with my Xbox kicking all my devices off wifi and causing my whole system to reboot.  I am have no issu...
  • campolo313's avatar
    campolo313
    Aug 16, 2020
    FURRYe38 wrote:
    Do any of your consoles have automatic updates even when turned off? If so, possible the port is being reporting active when this happens.
    Yes, both my Xbox are set to "Instant On" and my Switch is also, so I think they are holding the port open once it has been used.  But it does look like UPnP is doing it's job and deleting the Port Mapping when another system requests it, it just doesn't delete it when the system Powers Down, so I'm just going to monitor it.
    I do have good news as I was able to just play an hour and a half of Breakpoint with the guy that was crashing me, so I am going to mark this thread as solved.
    For those looking for help in the future, here is what ended up being my solution:
    Upgrading to the latest firmware (V3.2.16.6_1.4.4)
    Changing NAT Filter from Secure to Open
    This gave all my systems Open NAT and Full Cone NAT.
