Blairkob
May 05, 2021Follower
RBK753S adding a 2.4ghz router
I have an RBK753S bought at costco. Base plus 2 satellites. I need to add a router to the system for 2.4ghz devices (light buldbs) can it be done?
May 05, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Since telnet is not supported or available on Orbi AX system, Separation of SSIDs is not supported on Orbi AX.
Thank you.
Blairkob wrote:I have an RBK753S bought at costco. Base plus 2 satellites.
can it be done?
