k_schnaidt
Dec 17, 2021Tutor
RBK753S connection/streaming issues when satellites are connected
I recently setup a brand new Orbi RBK753S mesh wifi system. I followed the steps recommended in the manual for setting the system up. Upon completion of setup everything seemed like it was working. T...
ray_furry
Dec 17, 2021Tutor
yeah...im having the same problems
- FURRYe38Dec 17, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Try disabling Armor on the Orbi app, There should be a settings under the Armor tile to disable that feature. After you disable it. Power OFF the RBR for 1 minute then back ON. See what happens.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- ray_furryDec 17, 2021Tutor
How much does support charge now days?
- k_schnaidtDec 17, 2021Tutor
"NETGEAR provides complimentary technical support for NETGEAR products for 90 days from the original date of purchase."
I have not contacted them yet. I started here...
