k_schnaidt
Dec 17, 2021Tutor
RBK753S connection/streaming issues when satellites are connected
I recently setup a brand new Orbi RBK753S mesh wifi system. I followed the steps recommended in the manual for setting the system up. Upon completion of setup everything seemed like it was working. T...
Dec 17, 2021Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Try disabling Armor on the Orbi app, There should be a settings under the Armor tile to disable that feature. After you disable it. Power OFF the RBR for 1 minute then back ON. See what happens.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
k_schnaidt
Dec 17, 2021Tutor
ISP equipment I will have to get back to you on as I am not home at the moment. I can tell you that it is a fiber uplinked ONT and the speed I pay for is 1GB up/down. When I test my router connection to the ONT it is consistently 900MB up and about 500-600MB down
House + Garage is about 5000 square feet.
Distance between router and satellite-1 is roughly 30 feet. Router to Satellite-2 is about 40-50feet
I kept the channel settings on default - 2.4=auto 5G=48
There are about 6 other wifi SSID's that I can see from my neighbors. When I get home from work this evening I will factory default and leave Netgear Armour off when I setup again. If I am still experiencing issues I will do the steps below as you recommend:
"Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s)."
"try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz."
Update coming this evening...
- FURRYe38Dec 17, 2021Guru - Experienced User
OK let us know how it goes this evening.
- astainbackDec 17, 2021Apprentice
I have posted about this in the past.
Honestly, I think the issue is 2.4ghz and 5ghz devices bouncing back and forth.
Some devices are more sensitive to having both.
Again, this is what i think.
My Roku device is older, and stays connected better than the newer chromecast which loses connectivity constantly. AND... it is worse when I have the satellite hooked up. I gave up on that piece of crap months ago. I still have some issues. I plugged it back up recently and it made everything worse. So back to collecting dust again.
I really think if you could have separate SSIDs, this thing would work better.
I am shopping for a new router now, and I can't decide what to get. I bought this setup in Jan of 2021, so return is not possible.- k_schnaidtDec 21, 2021Tutor
Just curious...have you tried turning off the 5G radio in wifi settings so that all of your devices connect via 2.4? If you did try it what were the results?
- k_schnaidtDec 20, 2021Tutor
After the factory reset:
I did the factory reset on Saturday night. After setting it up again I disabled Netgear Armor. In the morning on Sunday my wife and kids were streaming on their devices and thought it was better but still having some of the same intermittent issues. I decided to make a slight adjustment to the positioning of one of the satellites.
Initiall setup:
I had my router in the basement furnace room - Satellite-1 in the basement main living room area (about 30 feet from router) - Satellite-2 in the garage. Both satellites were connected to the network via the router.
New setup:
-Router still in the furnace room where the ISP ONT is located - Satellite-1 is now upstairs in the kitchen which adds another 10-15 feet of distance from the router and of course the floor in between levels. Satellite-2 is still in the garage. Satellite-1 is connected via the router and satellite-2 is connected via satellite-1.
Testing after Satellite-1 adjustment:
So far the wifi reliability is much better throughout the house. There is still more testing needed to confirm this as a solution. I will do some online gaming in the next couple days and additional streaming via the other wifi devices. If I still notice any issues I will try the below recommendation:
I will post another update after Christmas. I have faith that I will get this thing working rock solid by then. It just shouldn't be this difficult. I am certainly glad I have an IT background in this situation. :) Happy Holidays
- FURRYe38Dec 20, 2021Guru - Experienced User
Just curious, where is this "furnace room" located and whats all in this room and what is the walls made up of?
