tdannerec
Jul 20, 2023Follower
RBK753S need to add another satellite
I need to add another Satellite to my RBK753S what are my choices since I can't seem to find just a RBK753 Extender/Satellite.
Jul 21, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
