iddoav
Jun 26, 2020Aspirant
RBK753S partial wired connection
I need to cover a pretty wide area with the mesh system and have a couple of questions 1. Wired vs wireless? I looked at the available configurations of wire vs wireless here: https://kb.netgea...
iddoav
dsThank you!
Super helpful.
Yes, that works just fine. In older terminology, that is a daisy chain configuration.
Perfect Thank you!
The first satellite will need to be within the RF footprint of the router. How far will you wire the second satellite from the first?
Around 50ft
How far will the first satellite be from the router?
ON a second floor more or less the same connection
Not sure about what you mean by the last question. The router can connect multiple satellites -- but not additional routers (in router mode that is)
By the last question I mean: My current mesh system required 8 mesh points. I assume the new one will require more than 2 mesh points (i.e. sattelite) as well. I am looking at: https://www.netgear.com/orbi/rbk753.aspx. I don't know if you can even buy a mesh point by itself, I *think* I need to buy a new system with a router and 2 mesh points. It sounds like from you answer like a router can operate like as mesh point (sattelite mode?).
If so - how many sattelites can a single router support?
Jun 26, 2020Guru - Experienced User
