JoshHen
Dec 28, 2020Guide
RBK753S Router Configuration Settings
 Hello Community,     I need help with the following settings on a new RBK753S.     Where do you set the DHCP lease time?  How do you change the admin username?  How do you disable SSID Broadcast on a...
- Dec 28, 2020
Admin in the default name and log in for Orbi systems. Can't be changed to something different.
ekhalil
Dec 28, 2020Master
JoshHen wrote:.....
There is no parameter for this. You need to use command line to set the wan_lease. The default WAN lease time is 1 hour.
root@RBR850:/# nvram get wan_lease
3600
JoshHen wrote:.....
Use the web GUI >> ADVANCED >> Administration >> Set Password
JoshHen wrote:.....
How do you disable SSID Broadcast on a specific channel? I need this capability for IOT devices?
Unfortunately this is not possible in Orbi AX. This funtionality was available in previous firmwares but was removed. The functionality is availble in the Orbi AC though.
Dec 28, 2020Guru - Experienced User
And you would enable Telnet where?
ekhalil wrote:
JoshHen wrote:.....
3600
