JoshHen
Dec 28, 2020Guide
RBK753S Router Configuration Settings
Hello Community, I need help with the following settings on a new RBK753S. Where do you set the DHCP lease time? How do you change the admin username? How do you disable SSID Broadcast on a...
- Dec 28, 2020
Admin in the default name and log in for Orbi systems. Can't be changed to something different.
ekhalil
Dec 28, 2020Master
JoshHen wrote:.....
There is no parameter for this. You need to use command line to set the wan_lease. The default WAN lease time is 1 hour.
root@RBR850:/# nvram get wan_lease
3600
JoshHen wrote:.....
Use the web GUI >> ADVANCED >> Administration >> Set Password
JoshHen wrote:.....
How do you disable SSID Broadcast on a specific channel? I need this capability for IOT devices?
Unfortunately this is not possible in Orbi AX. This funtionality was available in previous firmwares but was removed. The functionality is availble in the Orbi AC though.
JoshHen
Dec 28, 2020Guide
Thank you for the speedy response.
I didn't see the option to change the admin username when I went through the webgui, only the password. Also, can I install a old version of the firmware?
- FURRYe38Dec 28, 2020Guru - Experienced User
- ekhalilDec 28, 2020Master
JoshHen wrote:.....
I didn't see the option to change the admin username when I went through the webgui, only the password. .....
yes, admin is the default user name. Can only be changed using command line access, which -unfortunately- was removed in recent firmware update. I still have command line access since I never did factory reset since the time this was removed in the firmware. :D
root@RBR850:/# nvram get nvram show | grep admin
http_username=admin
JoshHen wrote:
.... Also, can I install a old version of the firmware?Yes you can. Go to the download page https://www.netgear.com/support/product/RBK753S.aspx#download and choose the firmware that you want. I'm not sure which firmware removed the SSID broadcast disable possibility though.
- JoshHenDec 28, 2020Guide
Thank you ekhalil,
I installed the oldest firmware from the link you provided but once the router and 2 satelites completed the updates there was not option to disable ssid broadcast. I do see the Enable Telnet option which i didn't see when I was running a newer version of the firmware (I used http://ipadress/debug.htm). Also, in general, the gui on the RBK753S lacks a number of advanced config options I was able to use with the RBR50. The more I use it, the more I notice.
Thanks again for the info on changing the default admin username.
Items like Beamforming, MIMO, FastRoaming, Daisy Chain are automatic now on Orbi AX thus why it's not a menu item like on Orbi AC models.
Orbi AX has never had options to disable either SSID broadcast. We have asked about that however have not seen any changes since Orbi AX came to market. Probably won't.
