JoshHen
Dec 28, 2020Guide
RBK753S Router Configuration Settings
 Hello Community,     I need help with the following settings on a new RBK753S.     Where do you set the DHCP lease time?  How do you change the admin username?  How do you disable SSID Broadcast on a...
- Dec 28, 2020
Admin in the default name and log in for Orbi systems. Can't be changed to something different.
JoshHen
Dec 28, 2020Guide
Thank you for the speedy response.
I didn't see the option to change the admin username when I went through the webgui, only the password. Also, can I install a old version of the firmware?
Dec 28, 2020Guru - Experienced User
