JoshHen
Dec 28, 2020Guide
RBK753S Router Configuration Settings
Hello Community, I need help with the following settings on a new RBK753S. Where do you set the DHCP lease time? How do you change the admin username? How do you disable SSID Broadcast on a...
- Dec 28, 2020
Admin in the default name and log in for Orbi systems. Can't be changed to something different.
Dec 28, 2020Guru - Experienced User
Ok, kinda doubtful NG will any any advanced settings. They seem to be tuning the UI and FW for more automatic operation, less user configurations.
Good Luck.
JoshHen
Dec 29, 2020Guide
Thanks FURRYe38,
Yeah, hopefully someone will come up with a custom frimware like they did with the RBR50.
- FURRYe38Dec 29, 2020Guru - Experienced User
They'll need get an Orbi AX system to do any development. Not sure if Voxel will be getting on. He seems busy with his current projects. :smileyembarrassed:
