lec96
Nov 30, 2024Aspirant
RBK753S satellite flashing white
RBK753S router and one satellite are fine, router firmware 7.2.6.31. The other satellite flashes white continuously.. I've tried holding down reset while powering on, only resetting while already po...
lec96
Dec 02, 2024Aspirant
Thanks for the detailed reply. Had a long call with Netgear support, reboot as described, factory resets of RBR and the 2 RBSs, it was determined that the one with the flashing white light is dead (3 years old). 2400 sq ft house and the dead RBS was about as far away as can be on another floor.
After I went through all that, a white light remained (not blinking). Today I did a factory reset and again, and the white light is gone.
Dec 02, 2024Guru - Experienced User
Ok, for that size of home, the RBR and just ONE RBS would be needed. You might turn OFF one RBS and observe to see if you need a 2nd RBS. Too Much Wifi: https://youtu.be/UR0viMLISz4
- lec96Dec 08, 2024Aspirant
That's just what we've done. Our concern had been making sure the car could have access to wifi for software updates. There hasn't been one since this happened so we shall see.
- FURRYe38Dec 08, 2024Guru - Experienced User
How often is the car updated?
Check with the car Mfr to see when SW is updated.
