lec96
Nov 30, 2024Aspirant
RBK753S satellite flashing white
RBK753S router and one satellite are fine, router firmware 7.2.6.31. The other satellite flashes white continuously.. I've tried holding down reset while powering on, only resetting while already po...
Dec 02, 2024Guru - Experienced User
Ok, for that size of home, the RBR and just ONE RBS would be needed. You might turn OFF one RBS and observe to see if you need a 2nd RBS. Too Much Wifi: https://youtu.be/UR0viMLISz4
lec96
Dec 08, 2024Aspirant
That's just what we've done. Our concern had been making sure the car could have access to wifi for software updates. There hasn't been one since this happened so we shall see.
- FURRYe38Dec 08, 2024Guru - Experienced User
How often is the car updated?
Check with the car Mfr to see when SW is updated.
