QP70325
Jan 23, 2021Aspirant
Rbk753s want satellites to connect to router only
Currently have the satellites connecting o each other (daisy chain) but i want them to connect to router only. Currently have wifi 6 RBR750 and 3 satellites (RBS750) thst keep connecting to each oth...
Jan 23, 2021Guru - Experienced User
I
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Placement is key here since Daisy Chain is Automatic. So you'll want to be sure to place the RBS out in a Star or Spoke formation out from the RBR, not out in a line from from the RBR.
QP70325
House is 5000 SQFt
satellites are 30-40 feet away.
Cable Modem is an Arris. Model - TG2492LG-LIB
- FURRYe38Jan 23, 2021Guru - Experienced User
What mode is the Arris modem working in? This has a built in router I beleive. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
