QP70325
Jan 23, 2021Aspirant
Rbk753s want satellites to connect to router only
Currently have the satellites connecting o each other (daisy chain) but i want them to connect to router only. Currently have wifi 6 RBR750 and 3 satellites (RBS750) thst keep connecting to each oth...
QP70325
House is 5000 SQFt
satellites are 30-40 feet away.
Cable Modem is an Arris. Model - TG2492LG-LIB
Jan 23, 2021Guru - Experienced User
What mode is the Arris modem working in? This has a built in router I beleive. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
