mohitkhatri88
Aug 10, 2021Follower
RBK753S with CBR750 and xfinity
Hi,
I have an RBK753s system: https://www.costco.com/netgear---orbi-rbk753s-ax4200-wi-fi-6-mesh-router-with-two-satellite-extenders%2c-one-year-advanced-cyber-security-included.product.100533367.html
I am moving to XFinity, and had few questions:
1. Would i be able to use the CBR750 modem/router combination(https://www.netgear.com/home/wifi/mesh/cbr750/) and not have to pay Xfinity for their's.
2. Would RBK753s work with CBR750?
3. Are there any other modem's by Netgear that may work in my situation.
Thanks for your help,
Mohit
1 Reply
mohitkhatri88 wrote:
Hi,
Something to ask the ISP about...However it should be supported. Ask to be sure.
2. Would RBK753s work with CBR750? Only the RBS750s will work with the CBR750 system. The RBR750 won't work as a RBS.
Yes, CM1000, 1100, 1200, 2000 series cable modem only units will work with your RBK750 system.
