ethanchueh
Jan 17, 2023Aspirant
RBK762 2.4GHz mode not running 600Mbps ? only 286.8Mbps
just upgrade RBK50 to RBK762 and found out the 2.4GHz mode shows max speed is 286.8Mbps, which is not expected speed(600Mbps) as RBK760 SPEC shows. btw, i've try turn off the 20/40 coexistence, seems...
Jan 18, 2023Guru - Experienced User
What firmware is loaded on your system?
- ethanchuehJan 18, 2023Aspirant
i'm using latest 6.3.6.4. the 2.4GHz still shows 286.8Mbps. try reboot after disable 20/40 coexistence, nothing change.
any suggestion ?
- FURRYe38Jan 19, 2023Guru - Experienced User
Can you post a screen capture of the RBRs Advanced tab page and the 2.4Ghz section here and post a screen capture of the RBS web page as well showing the 2.4Ghz section as well.
Please edit out any SSID names and PWs or serial numbers before posting.
