tomtom1126
Apr 10, 2023Aspirant
RBK762S disconnected frequently.
I brough ORBI RBK762S 1 weeks ago, router unstable and disconnected frequently even I chat with Netgear apps support, the guy told me reset the router (actually I did it 2 times before). I reset the ...
Apr 10, 2023Guru - Experienced User
What modem/gateway is the router connected to?
tomtom1126
Hi Plenams,
Thanks for your below feedback.
Modem is come from service provider Huawei (EchoLife HG863).
Default Gateway 192.168.1.1
Regards
Tom
- plemansApr 10, 2023Guru - Experienced User
might check this thread:
- tomtom1126Apr 10, 2023Aspirant
Hi Plemans,
Thanks again for your below information.
But I use this Modem/router Huawei EchoLife HG863 for over 10 years.
I use Apple Airport extream / Orbi RBK20 /Asus Zen before without any problem.
but for my new purchase ORBI762S keep on disconnected, 3 times today (till now).
I will try to check my service provider for what is going on!
Regards
Tom
- FURRYe38Apr 10, 2023Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-ModeTry option #2 first...
tomtom1126 wrote:
Hi Plenams,
Regards
Tom
- tomtom1126Apr 11, 2023Aspirant
Dear Furrye38,
Reference to your below, I am not sure my IPS modem build in router or not, but I am sure it has no wifi. I am checking with my service provider to clarify the problem with my new router.
Anyway thanks!
Tom
- FURRYe38Apr 11, 2023Guru - Experienced User
Keep us posted.
