titaniumrx8
Nov 16, 2022Apprentice
Rbk763 and Bryant Connex Thermostat
Previously, using RBK753, The issues of connecting the Connex was solved by the following: So, currently these are the settings that are working: 1. AX disabled for the 2.4ghz band 2. RTS/CTS set ...
titaniumrx8
Nov 21, 2022Apprentice
After trying all previous steps to get the Connex to connect, I was going to set up an old 2.4ghz extender. Due to other commitments I didn't get around to setting up the extender. Last night, I found that the Connex had joined the Wifi and was accessible.
I haven't made any changes to the Orbi or the Connex settings in the past week so this is a mystery.
But somehow Connex is capable of figuring out how to connect to Orbi 763 without doing anything special to the Orbi or the Connex. It took a week but it sorted itself out.
Nov 21, 2022Guru - Experienced User
Something to try next time, turn OFF ALL RBS and see if the next device or what you are trying to connect can connect. Possible that some devices have problems seeing multitudes of wifi signals and can't lock on.
- titaniumrx8Nov 22, 2022Apprentice
That was the first thing that I did. Not my first rodeo trying to get this thermostat connected to Orbis.
