titaniumrx8
Nov 16, 2022Apprentice
Rbk763 and Bryant Connex Thermostat
Previously, using RBK753, The issues of connecting the Connex was solved by the following: So, currently these are the settings that are working: 1. AX disabled for the 2.4ghz band 2. RTS/CTS set ...
Nov 21, 2022Guru - Experienced User
Something to try next time, turn OFF ALL RBS and see if the next device or what you are trying to connect can connect. Possible that some devices have problems seeing multitudes of wifi signals and can't lock on.
titaniumrx8
Nov 22, 2022Apprentice
That was the first thing that I did. Not my first rodeo trying to get this thermostat connected to Orbis.
