titaniumrx8
Nov 16, 2022Apprentice
Rbk763 and Bryant Connex Thermostat
Previously, using RBK753, The issues of connecting the Connex was solved by the following: So, currently these are the settings that are working: 1. AX disabled for the 2.4ghz band 2. RTS/CTS set ...
FarmerBob1
Nov 21, 2022Luminary
On my RBK853, when having these problems, I would try to back off everything to do with 5G. Turn its power way down and 2.4 way up. Turn off all the New Gen Toys on the 2.4, on for 5G and that usually made it easier.
titaniumrx8
Nov 22, 2022Apprentice
Tha was the second thing that I did. Didn't help.
Previously, the only adjustment that seemed to work reliably was changing the CTS/RTS but the RBS760 doesn't appear to expose this setting via the app or web page.
The Connex has been jumping on and off the mesh so I think I'm back to adding an extender with a different ssid and only 2.4 enabled. Hate to do it but not replacing the $700 thermostat until it is dead.
