Pelste
Nov 21, 2022Aspirant
rbk763 is possible change IP router and satellite?
Hello all. it is true that the network between router and satellite must be numbered 192.168.1.xxx ( for work with mesh) or is possible give free network like 192.168.0.xxx? I wanted to take th...
- Nov 21, 2022
yes
Nov 21, 2022Guru - Experienced User
Yes, both RBR and RBS have to be on same IP address subnet pool. You can change the RBRs IP address to something different. I use 192.168.0.1 myself on mine. I also use .100 thru .200 has a default IP address pool. This gives me room for Static IP addressed devices on either side of this pool
Pelste
Thanks this makes me happy.
Another question if I put router and satellite in AP mode the mesh works without problem?
