wasnt
Oct 26, 2022Aspirant
RBK763S - Latest Firmware Issues (V6.3.6.2_1.2.66)
I just received the latest firmware update (V6.3.6.2_1.2.66) for my RBK763S system (1 router, 2 satellites). Web Interface on Desktop PC On the 'Firmware Update' screen (under Advanced -> Adm...
Oct 26, 2022Guru - Experienced User
The RBS should be updated first before the RBR.
- wasntOct 26, 2022Aspirant
I didn't update anything. It was auto-updated. How do I update the RBS separately now? If The RBS needs to be updated first, why didn't it happen automatically? Why wasn't there a note/email/text/anything from Netgear about this requirement?
- FURRYe38Oct 26, 2022Guru - Experienced User
Was there a auto update disable seen on prior version of FW on the FW update section on the RBRs web page?
Do the RBS show up as connected on the RBRs web page at all? Might need to downgrade the RBR back to prior version to get the RBS to connect then update them first, then bring the RBR back to current version.
Thanks, I will look into that. I can tell you that I checked for firmware the other day and only found an update for the RBR, not the RBS. I didn't have auto-update selected because I work from home, that is why I was shocked to have a firmware update occur automatically. I am still not sure how it happened, but I know when because it happened overnight and my phone didn't reconnect automatically.
