Soloman
Jun 29, 2022Star
RBK763S (AX5400). SSID reset required
Ever since purchasing my new RBK 763S, I have had an issue with a requirement to setup a new SSID after my Internet connectivity is dropped, or if we experience a power outage. If I do not change th...
- Jun 30, 2022
Yes. I use 50% on mine. Seems to also help steer devices to RBS as well vs the RBR. Orbi systems are fairly powerful.
Jun 29, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
You don't need to change the SSID or should need a reset.
80 devices is kinda high...not sure if this will impact or cause what your seeing.
Can you disable say half of these device and see if this changes the behavior?
- SolomanJun 29, 2022Star
Current Software version is V6.3.1.0_1.1.41. Separation is ~20 ft to 1 Satellite (also through walls) and ~35 feet to the second Satellite (also through walls). About half of the devices are wired using Ethernet and Netgear switches. When fewer items are connected I was still having issues connecting my iPad with the previous SSID, changing my SSID was a solution one of the Netgear Tech support reps suggested after walking through the initial setup with me.
- FURRYe38Jun 29, 2022Guru - Experienced User
Soloman wrote:
Current Software version is V6.3.1.0_1.1.41. Separation is ~20 ft to 1 Satellite (also through walls) < this would be WAY TOO close for this one RBS to the RBR.
and ~35 feet to the second Satellite (also through walls). About half of the devices are wired using Ethernet and Netgear switches.<What model # are these switches? When fewer items are connected I was still having issues connecting my iPad with the previous SSID, changing my SSID was a solution one of the Netgear Tech support reps suggested after walking through the initial setup with me.
What CAT# lan cable are you using?
Sounds good I will try separating the 1 Satellite that is within 20 feet - to greater than 30 feet. My LAN cables are mostly CAT6, although some of the in wall lines are still CAT5e. The switches are: GS208 (1), GS205 (2), GS908 (1), GS308V3 (1).
